SHC stucking on bootup
  • Hi I really need your help I’ve tried to get answers but most of the things are in German so I don’t understand.. my booster I have reset it and it’s stuck on booting mode and there is a symbol under like a triangle I have looked at the meaning of the symbol and it says
    Continuously lit caution sign
    A system-relevant note (e.g. weak radio transmission, confirm e-mail address, software update) has been detected by the SmartHome central unit and
    can be called up in the SmartHome app.
    Continuously lit envelope
    It’s not doing anything not giving me a pin to carry on it’s just stuck please if anyone could help that would be much appreciated thank you
  • A bit more information would be helpful.
    I asume it's a SHC1 because you have a display.
    What is the firmware version you are running on, press the right bottom for a second to display.
    Why did you reset it?
    Was it functional before that?
    Did you already migrate to the local interface?
  • LIVISI
    Hat den Titel des Themas von „Aleyna“ zu „SHC stucking on bootup“ geändert.
