• I want to reconnect the thermostat to the switch, is that possible? And how? The switch can be added on its own and works! Thermostat also only connects on its own. I just don't understand how you tell the thermostat which switch to operate or was this switch automatic and special for the thermostat without you having to do extra actions?
  • In the Livisi SH system the thermostats (RST or WRT) do not control directly the boiler switch (PSS) on or off. Netatmo or Salus thermostats have dedicated switch that does this automatically. For Livisi you have to create two scenarios manually similar to these two below. Bear in mind that if you use RST on all your radiators there are periods when all RST are closed so you have to have a bypass valve mounted somewhere (sometimes the boiler include this) between flow and return pipe.
    The scenario 1 below has to be created for each room individually since you want to turn on the boiler when at leas one rooms need it. For scenario 2 you have to select all the rooms since you want to turn off the boiler only when all the rooms are above the target.
    Scenario 1 (Turning on the boiler)
    IF:
    - Current temperature > Raumklima (individually) > Change of temperature
    or
    - Target temperature > Raumklima (individually) > Change of temperature
    AND
    - Current temperature > Raumklima (individually) > Below target temperature
    THEN
    - On/Off > Boiler switch > Turn ON
    Scenario 2 (Turning on the boiler)
    IF:
    - Current temperature > Raumklima (all) > Change of temperature
    or
    - Target temperature > Raumklima (all) > Change of temperature
    AND
    - Current temperature > Raumklima (all) > Above target temperature
    THEN
    - On/Off > Boiler switch > Turn OFF
